Electric Car project - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-18-2006, 02:42 PM
38 special's Avatar
Be the MIRACLE!
Last journal entry: Running boards (part DUEX)
Just for fun go to Mechanix Illustrated on the web. It would be more work but they have an intresting battery cars and three wheeler as wheel as lawn mower engine powered 3 wheelers. You might get some ideas and find it interesting.
  #17 (permalink)
Old 05-18-2006, 09:29 PM
How about using a small truck such as a Ranger or S-10? Light weight and plenty of room to carry batteries outside the passenger compartment.
  #18 (permalink)
Old 05-19-2006, 07:02 AM
Older trucks make a good base for an EV. Here are some shots of one from a local show.
ID:	12341   Click image for larger version
ID:	12342   Click image for larger version
  #19 (permalink)
Old 06-20-2006, 12:42 AM
i have a 74 mazda formerly rotary pickup and it make a fine platform. i have 18 6volt batts in it. the way they assembled it they put 8 batts in the engine compartment and 10 batts under the bed. which was a mistake. i will put 4 batts in the bed and get some weight off the front end. it will do 40 miles to a charge easily. mine also has the tranmission, 4 spd. it sure is quiet. you need good brakes because it free wheels up to a light. in fact, you learn to watch for lights and back out a long ways ahead. it has an on board charger so if at work you can get near an outlet, problem solved.
  #20 (permalink)
Old 06-20-2006, 05:41 AM
There actually were a couple of electric Corvairs built by GM in the '60s as concepts. Electrovair II I've got 2 late model Corvairs, they're unibody and not all that light to begin with.
Conventional lead-acid batteries give off hydrogen when being charged. Make sure that the batteries are vented to the outside of the vehicle and that there's plenty of ventilation. One spark could bring back memories of the Hindenburg.
  #21 (permalink)
Old 07-05-2016, 11:13 PM
OldTech's Avatar
Don't be silly, they wouldn't let you smoke if it could burn... quote from a passenger on the Hindenburg.
It's unsinkable! Quote from the company rep aboard the Titanic...
Warnings of danger are for the folks in southern California. The rest of us have to work to find out who to sue.
  #22 (permalink)
Old 07-06-2016, 11:13 AM
evolvo's Avatar
Heathen
I'm toying with the idea of making this an EV. As it sits, 850#. I will have to use lithium or nicad as there is no where but the back seat to put the batteries. It's a 1937 Austin Seven. I'll have to build a frame and update the running gear because I don't think that the trans/rear end or wire wheels could take an upgrade from 12 HP to 50 or more and they certainly won't withstand the torque!
ID:	309457   Click image for larger version
ID:	309465   Click image for larger version
The Following User Says Thank You to evolvo For This Useful Post:
MARTINSR (07-07-2016)
  #23 (permalink)
Old 07-06-2016, 12:04 PM
ogre's Avatar
the 'Duracell Project'
nice 10 year old thread recovery with no additional useful info oldtech
evolvo- i still want to see you convert that thing to an e-car
The Following User Says Thank You to ogre For This Useful Post:
  #24 (permalink)
Old 07-06-2016, 04:43 PM
evolvo's Avatar
Heathen
Yeah, looking at post dates is something I forget to do. Just the fact that it was an EV thread caught my eye. The Austin would sure make a cool one though, eh!
  #25 (permalink)
Old 07-07-2016, 10:33 AM
I am hoping to see you proceed with this project! I have been a big electric car fan since the seventies but have never bit the bullet and did it! I have books I bought back then that would be cool to use, basic old stuff, 30-50 miles was super easy to get back then. With modern batteries (about $1500 at LKQ) it would be a breeze.
When I found the block cracked on my Rambler when I was building it I seriously thought of going electric and started studying it. I ended up going back to the flathead but really, it's not a big deal to go electric.
I have sense thought about a 20's car, for my daily driver every day. And going electric would be a blast! You know there were no electric cars than gas on the road up until the T was introduced?
  #26 (permalink)
Old 07-07-2016, 11:36 AM
bigblockragtop's Avatar
I was talking about electric cars with a fireman. He told me he just went through training on what to do when there is an electric vehicle stuck in water. He told me they were trained to sit by and basically wait until the batteries have died enough for the people to stop sizzling. Not sure how true that was... there goes my plans to buy a volt.
  #27 (permalink)
Old 07-07-2016, 01:57 PM
And what are your plans for when the gas car you are in is on fire? Geeez
  #28 (permalink)
Old 07-07-2016, 02:22 PM
Guest
Location: in the land of Trolls at least till the san andreas releases the big one
ahh... electric ...
back in the early 90s... inland motor showed a prototype pancake motor... 23" square... overall shaft lenght of 8".. yes from end to end.. it had 360 horsepower and 1,000 foot pounds of torque from 0 to 3600 RPM.. it was designed for local passenger busses. i think they were just going to figure out how to bolt it up directly to the differential. i really wanted a pair of them to mount between my friends boat transmissions and the 3" prop shafts. for those who are curious... 32" props with a 28 pitch 3 bladed.
for those making their own electric car .. could i suggest.. creating a form or plug and having a thermal vacuum forming shop make a custom battery box for you. it should be molded with structure to support the batteries.. its not that hard to do.. if the shop does not have to create the mold.. it won't even be expensive.
i personally wondered if the toyota prius drivedrain could be dropped into a much earlier toyota corolla.. why bother with engineering a bunch of stuff.. if you can just bolt it in. you would have to do some.. but crashed prius models do exist. if you can get them before the dismantler gets their hammers on them to sell parts off..
"Basics of Basics" Photographing your car. MARTINSR Hot Rod Art 89 03-31-2009 02:53 AM
New member with 70 Camaro project car. Rick Beil Introduce Yourself 2 10-02-2005 12:45 PM
Project Car Newbie Arcuden Introduce Yourself 2 07-30-2005 10:51 AM
looking for a good daily driver \ occasional project car dukin-it-out General Rodding Tech 6 11-18-2003 03:04 PM
Story time. Halloweenking Hotrodders' Lounge 17 05-19-2003 10:16 PM
