Electric Choke - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2013, 11:51 AM
Electric Choke
To power an electric choke on my '55 Ford 12V generator system I was told to run a wire from my starter solenoid to my electric choke. Is this the best spot to use to run the connection? I have mechanical gauges so I can not use the oil sender as a connection point. Also should I place a fuse in this wire and what gauge wire should I use? !
Old 02-14-2013, 12:54 PM
33Willys77's Avatar
You need to have 12v source to the choke when the key is in the run position, NOT constant. Also, the oil sensor wire for electronic guages will not have voltage. Do not hook the choke to your ignition power either, as it can take voltage away from your ignition.
The Following User Says Thank You to 33Willys77 For This Useful Post:
55 CrownVic (02-14-2013)
Old 02-14-2013, 07:16 PM
302 Z28's Avatar
The best way IMHO is to use a wire from the "F" terminal of your alternator. That way the electric choke only has power when the car is running.
Vince
changing a divorced choke to a electric choke? Help please?e 71GMC Engine 1 02-11-2012 05:14 PM
electric choke gcanavy Electrical 2 01-23-2009 12:01 AM
electric choke njbloodline666 Electrical 15 05-02-2006 05:55 AM
Electric choke 3100 Special Engine 10 04-23-2006 08:46 PM
electric choke SDSJap Engine 1 08-13-2004 08:41 PM
