Electric Choke Wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2007, 05:49 PM
Electric Choke Wire
I'm installing a new Holley Avenger carb with electric choke. I know not to put the hot lead from the coil side of the resistor, but is it ok to use the side that comes from the ignition switch, or, is there a better place to connect it.
Old 08-18-2007, 06:09 PM
302 Z28's Avatar
It has been covered before, but I do not mind going over it again. The proper way to hook up an electric choke is through a relay. One side of the relay coil is powered by the field coil of your alternator. The other side of the relay coil goes to ground. 12 volts from a fused source goes to one side of the normally open contacts of the same relay. The other side of the normally open relay contacts goes to your electric choke. With this configuration the only time the choke gets power is when the engine is running. When you are messing around with something else and you have the key on the choke is receiving no voltage.
Vince
docvette's Avatar
Wiki Edits: 12
Doc here,
General Mystery (GM) , usually runs a Choke RELAY off the Field wire of the alternator..(the brown wire).
In this configuration , the choke will not begin to open until the engine is actually running..so you don't attempt to start a cold engine on a wide open choke because you turned the key on to wash the windows , listen to the "Tunes" while loading the car, or Belting the kiddies in..defeating the purpose of the choke.
The Alternator MUST be putting out power (Engine turning) in order for the Choke element to get power through the relay from the battery before it opens AND must be "bumped" to slip the mechanical detents to return it to curb Idle.
The whole process takes about 3 minutes..and saves a lot of jump starts in a cold climate on a badly tuned car, with an older battery.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-18-2007, 06:28 PM
I have a one wire alternator.
Old 08-18-2007, 08:25 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Well then...
You can do it the OTHER way General Mystery Does it...
Obtain a Combination oil pressure / Switch sender...Where i/2 the switch is a pressure sender, and the other half is a standard on/off pressure micro switch..(tuns on around 10 lbs..)
The last option, is of course, any Fused (25 amps) Switched , 12 volt source, THAT is not the coil or alternator..But this gives you the least amount of control/failsafe over the choke.
Doc
Innovations
Corvette electric choke problems JG700 Electrical 5 07-01-2009 07:32 AM
Electric choke voltage Mertz Engine 36 04-22-2007 11:28 AM
Internally Regulated Alt... Only Way To Go!!!!! h0trod389 Electrical 3 10-15-2006 06:41 PM
Electric choke 3100 Special Engine 10 04-23-2006 08:46 PM
how can i hook up an electric choke? malibu68 Engine 2 04-27-2005 05:23 PM
