electric choke wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2009, 08:59 AM
Does anybody know the real reason why they say not to wire a electric choke into the battery side of a HEI distributor wire? A lot of my street rod friends have done this and say they have never had a problem. They say the electrical draw is so minimal that it won't hurt a thing. This makes sense to me.
The edlebrock installation manual says not to do this but does not give a reason why. Any answers out there?
Old 02-10-2009, 09:48 AM
most solid state dist have a minimum "turn on" voltage...
if the batt is weak or starter is working to hard/worn the added load of the 4amps +(?) choke on the dist wire can cause no spark....
if the alt amp load versus output on the dist at idle is high,,,the choke will rob volts and amps from the dist and that affects spark quality...
(depends but can ruin the spark intensity up to 2000 rpms)
stock wires are usually #12 or #14 so the last thing you want is more load=heat=lost amps power to the ign....
(what you do want is amps in reserve due to no heat)
there are more good reasons but it's more of a caution versus DO NOT...
the ign switch can handle 30amps plus, just wiser to use a second wire to the choke...
you can test to prove it is ok, depends on the specifics of the car....
Old 02-10-2009, 10:38 AM
Originally Posted by Denny
The best way is to route the choke stat feed wire to an ignition on wire for accessories.
Or better yet why not wire it to the alternator like the old factory method. When wired this way the choke will not start to heat up until the engine is running.
Old 02-10-2009, 11:03 AM
302 Z28's Avatar
That is the proper way to do it. Go one better and run it from a relay energized from the alternator.
Vince
Old 02-11-2009, 05:44 PM
electric choke
How do you safely wire an electric choke into a chevy altenator. What is the procedure?
Old 02-11-2009, 07:17 PM
302 Z28's Avatar
The wire to the choke or to energize the choke relay is connect to the field terminal of the alternator.
Vince
Old 02-11-2009, 09:19 PM
Safe Choke
Oh man ....wiring directly to the alternator gives me the cold chills for so many reasons.
I'd much rather you run a wire from the fuse box. At least then you have a fuse in circuit AND likely a fusible link. I seen no mention of fuses above.
Are you sure there's no wire in the harness for an electric choke?
You do want to be sure the wire is switched - only hot when the key is on.
Steve
Old 02-12-2009, 04:11 AM
aka Duke of URL
I'm still trying to get my seat cover out of my posterior. I can see the fires now...
It needs to be run off of a relay delivering full BAT VOLT on a keyed source fused.
aka Duke of URL
...sheesh...
Last edited by KULTULZ; 02-12-2009 at 08:49 AM. Reason: There Must Be An Echo In This Board
Old 02-12-2009, 05:56 AM
The factories have wired it from the alternator for years and there were are literally millions of cars built that way. As was stated the reason for doing this is so that the choke does not start to heat until the engine is running, a much better set-up if you think about it otherwise the choke will heat up whenever the key is on ready or not! Wiring a fuse into this would be no problem and I fail to see a fire hazard here. Using that relay would certainly be a good idea since it would be easier to apply full voltage when it is time for the choke to open.
Old 02-12-2009, 07:59 AM
GMs used an oil pressure switch to activate the choke once the engine is running. Also, GM internal regulator alternators have battery voltage at the threaded post of the alternator even when the engine is not running.
Old 02-12-2009, 08:47 AM
aka Duke of URL
... and I fail to see a fire hazard here.
You see no fire hazard with a HOT WIRE hooked directly to an ALT ARM?
Again-
You want it connected to FULL BATTERY VOLTAGE through a keyed source. If it energizes with the IGN KEY on ACCESS position, it will burn the element eventually. You may notice that the vacuum inlet usually used for hot air intake has an inlet filter for cold air intake (previously used as vacuum draw for hot air) to cool the element. Also do not tie it in with any IGN circuits. This may lead to erratic engine running.
Connecting to S on the ALT does not source 12V. The STATOR connection is used in a factory setup as the choke is energized by both hot air (off exhaust manifold) and electricity. The STATOR supplies about 9V to allow the choke to vary in it's opening rate to allow for cold ambient intake air or partial cold starts. The electric power source allows for quicker choke opening for emmission purposes.
The choke circuit should operate off a dedicated relay delivering full BAT VOLT (13.2V).
Any heavy draw electrical retrofit (fuel pump-headlamp-ignition system-etc.) to an early chassis should have it's own fused/proper wire size relayed power source.
Old 02-12-2009, 09:03 AM
I decided to do a quick search to see what I could find on this and there are dozens of links to Ford, GM, etc even Toyota and Mazda even back pre-smog for the American cars. The first link here shows a typical diagram of a factory choke/alternator wiring using a fused circuit and a relay to provide full voltage.
http://wiki.datsun1200.com/index.php...and_Adjustment
Here is concerning a GM alternator/choke
http://camaroforums.com/forum/archiv...p/t-13408.html
http://www.chip.com/buick/techtips/choke.html
http://www.yotatech.com/f131/1985-22...c-choke-99608/
http://www.jeepforum.com/forum/showthread.php?t=88020
http://forums.stangnet.com/772556-he...tic-choke.html
There are dozens more and this is done all the time, it actually is the proper way to wire a choke and is the way the factories did it and I honestly don't see the fire hazard.
Old 02-12-2009, 09:25 AM
footnote add:
just came across, the Holley electric choke kit instructions calls for a 10amp inline fuse!!!!
that tells you the amps load on the wiring as the element heats up adding more and more ohms resistance as it gets hotter and hotter is alot more than:
"just a small amount" of drain on the coil volts and amps wiring supply....
some simple logic:
"if" just a jumper wire HEI to the choke element was "kosher"....
detroit would have done it and saved millions of dollars!!!!
what is the car you want to wire?
Old 02-12-2009, 09:54 AM
If a relay is used, and it should be, then 10 AMPs will not matter. Just use one of the common universal 30 AMP relays and then the only load on the control would be the small coil load on the relay.
Wiring an electric fan w/relay horvath Electrical 46 11-20-2014 03:46 PM
Quadrajet electric choke. kegross1 Electrical 7 09-21-2009 08:01 AM
Is Electric Choke Usually Wired thru Accessory? JohnTN Engine 3 01-05-2008 08:49 PM
Edelbrock carb electric choke problems csilva84 Engine 3 10-06-2007 08:40 PM
electric to manual choke conversion hiball Engine 3 12-21-2004 08:23 PM
