Electric choke wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2009, 07:36 PM
streetrodderbn's Avatar
Certifiable Streetrodder
I have researched the site on electric choke wiring, I'm working on my son's 78 z28 with a carb shop quadrajet with electric choke. I swapped the original climatic choke from the z28 carb, but it would'nt function correctly, I then replaced the electric choke and wired it to the energize wire of the alternator, but it is making the alternator sense a draw in the battery, and causing it to constantly spike the charge(it shows 18 volts charge on the voltmeter) Can I simply run a wire with inline fuse from the ignition switch or ign. hot circuit on the fuse box if I assure it is a fused circuit? or do I have to run a relay?
Old 06-11-2009, 08:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you wire the choke to any other circuit, the choke will begin to heat up as soon as the key's turned on. Not a problem, usually- but one you should be aware of.
I suppose a relay would be the "correct" way of doing it, but IMO, simply wiring it to a switched, fused 12 VDC circuit that can handle the additional draw, or use a circuit that's usually present in the fuse box as an auxiliary, should be fine.
As for the voltage- this is not because the alternator senses the tiny draw from the choke. There's something else going on, possibly a bad regulator or gage.
Old 06-11-2009, 08:24 PM
justold's Avatar
To answer your question it is yes . to trouble shoot your problem there should be a conductor already there for the choke , it is controlled by an oil pressure switch located near the distributor or just above the oil filter .
Hope this helps .
Old 06-12-2009, 04:48 AM
Thanks, that's the direction I'll go. the alternator seems to function fine without the choke plugged in on the same circuit as the energize wire!
Wiring an electric fan w/relay horvath Electrical 46 11-20-2014 03:46 PM
Quadrajet electric choke. kegross1 Electrical 7 09-21-2009 08:01 AM
Is Electric Choke Usually Wired thru Accessory? JohnTN Engine 3 01-05-2008 08:49 PM
Edelbrock carb electric choke problems csilva84 Engine 3 10-06-2007 08:40 PM
electric to manual choke conversion hiball Engine 3 12-21-2004 08:23 PM
