Electric Cooling Fans - Top Manufactures - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2012, 10:35 PM
64Joker's Avatar
64Joker
Besides "SPAL" brand electric cooling fans, what are a few other top rated company's that produce electric fans?
Old 07-16-2012, 12:26 AM
Docc's Avatar
Dry Heat
Last journal entry: along the weird tale..
I have always used Spal fans..always been good for me.. is there a reason you want something different ?
Old 07-16-2012, 07:55 AM
65 Imp SS's Avatar
I too have run spals. Currently running Maradynes champion series M122, which is the higher amp one vs their M123 Maradyne High Performance Fans with no problems at all.
Old 07-16-2012, 11:11 AM
Irelands child's Avatar
The last car had a SPAL, the current one has a CCM (part of Walker Radiator Co.) and fan blade actually looks like a SPAL as well
Both were/are good as far as moving LOTS of air. The nice part with the CCM is the integral shroud that fits my '32 radiator as well as a couple of relief flaps. It also has a strong mounting bracket.
This is the CCM -
The photo was taken last winter during some other changes
Irelands child
Old 07-16-2012, 04:06 PM
Joe G's Avatar
If there's room for a puller, Cooling Components fans are my first choice too.
Lately, I've been wiring them to be 2-speed and using a Dakota Digital PAC-2700 digital fan controller and a temp sensor in the lower radiator tank. It works so good, you wouldn't even believe it.
Joe G.
Old 07-16-2012, 05:03 PM
TexasDave's Avatar
Gear Head
I've used SPAL fans for years with good results.
A Flex-a-Lite almost took off a couple of my fingers a few years back. That thing was awesome
Old 07-18-2012, 12:39 PM
I am using a Cooling Components shrouded electric fan with good results. They are pretty low profile for limited space.
Old 07-18-2012, 01:10 PM
This is the photo I 'alluded to' above. Sorry, but occasionally things just don't happen as planned:
Ooops - this site does it to me again
Irelands child
Old 07-21-2012, 06:17 AM
SSedan64's Avatar
The OEMs have several good options aswell.
Lincoln Mark VIII
Ford Taurus
Dodge Intrepid
Chevy Camaro w/LS Eng.
cooling fans, cooling system
cooling fans weekend warrior Electrical 6 11-25-2010 02:35 AM
Electric Cooling fans, Help picking one RAW Engine 7 02-28-2007 09:52 AM
cooling fans ? bella Engine 2 06-20-2003 12:02 AM
Electric cooling fans. "Pusher" or "Puller"? NASCAR314 Engine 4 11-09-2002 04:06 AM
Electric Cooling Fans (CFM's) 41willys Engine 1 10-06-2002 05:10 AM
