maybe a die grinder?
I have a Craftsman Electric Die grinder. It works well with 1/4" shank carbide cutters or the cutoff wheel adapter. I'll use this most of the time to save wear and tear on the compressor...
Mark |
I also use an air-powered die grinder alot, but, after watching one of the "American Chopper" show, I noticed Paulie using a 4 1/2" Dewalt with a cutoff blade. I tried it with my Milwaukee 4 1/2", and it actually works quite well-the blades last longer, and, if you have larger hands you can control the cuts.
craig |
die grinder with 3m disks-another option
I have used my die grinder with an adapter for 3m or rollock disks - similar to the ones everyone uses to remove gaskets with- just get lower grit ones for grinding in real tight places. It doesn't work as well as a grinder;the disks wear out faster; but it is an option.
Hey Thanks everybody. I noticed a die grinder at Harbor frieght..seems to have the revs(25000). Maybe I'll give that a try.
Window-I noticed the electrics on American Chopper also..I emailed the show..No response. When you say 4-1/2 DeWalt..what do you mean..Is that a die grinder? Thanks, Keith |
| Electric cutoff wheel? | ComingApart | General Rodding Tech | 18 | 06-15-2005 08:39 PM |
| New Scan Tool user | 36scsc | Electrical | 3 | 01-29-2005 07:35 PM |
| Electric Cutoff Tool ? | Slickriffs | Body - Exterior | 9 | 11-03-2004 09:44 PM |
| Home Mechanic's Tool Guide | bigbird | Hotrodders' Lounge | 3 | 08-24-2004 10:06 PM |
| front end popping | maddmaxx | Suspension - Brakes - Steering | 4 | 11-15-2003 08:24 PM |
