i want to run an electric fan on a thermostat controled switch in a 63 bel air wagon with a sbc 350. what switch would i use and what would be the best way to wire it up
This guy's got a schematic that's just what you're looking for.
Check it out! http://www.classictruckshop.com/clubs/earlyburbs/projects/cooling/fans.htm[url]
Spoonie
Follow this. Go to
<a href="http://www.classictruckshopURL.com" target="_blank">http://www.classictruckshopURL.com</a>
Then go to truck clubs in lefthand column.
Then go to old burb club, then how to page.
The fan page is linked by a picture tword the bottom of the page in the middle.
Vintage Air makes a nice unit that I used to control my Spal electric fan. It consists of a variable manual rotary switch and a heat probe. The probe can either be screwed into the pet**** bung or just speared through the cooling fins ( not literally). If you are running a/c , you ight want to wire it directly through your compressor circuit, so that it comes on whenever the A/C kicks in and also wire it via a standard relay and set the variable switch at a temperature that you would want the fan to kick on at. If you have an actual heat guage in your system this is very easily done. Wait until the water temperature heats up to the desired temp. and turn the switch control to the position that activates the fan at that level. You can either control the ground interrupt to turn the fan on or switch the power with the relay. Good luck.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
