electric fan ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-09-2010, 02:22 PM
Originally Posted by Area_51
hi guys i have a new 350 with a 14 in electric fan and a 195 stat with a switch that my fan goes on at 200 and off at 185 my problem is that once my fan goes on at 200 my temp is staying at 200 and my fan is not going off since it is staying at 200.
any ideas ?
let me know dan
A 195 'stat will have the coolant at 200 to 205, which keeps your 200 degree switch energized. Either get a 210-220 switch or a 180 'stat.
Bogie
  #17 (permalink)
Old 06-09-2010, 03:47 PM
electric fan ?
no it dosnt go off unless i turn the car off.
51 chevy coupe
  #18 (permalink)
Old 06-09-2010, 10:01 PM
techinspector1's Avatar
Wiki Edits: 326
i don't have the room for a mechanical fan i only have a fingers with between my pulleys and my radiator
What's goin' on here? The car came with a 6-banger, which was way longer front to rear than the little V8 you're using. You should have room for TWO mechanical fan systems.
  #19 (permalink)
Old 06-09-2010, 10:36 PM
OLNOLAN's Avatar
I was thinking the same thing.
First, Cool car Area 51, I like the user name too. You gonna use the '53 grill or the '51? T.I., from the photos it appears to have a MII front end grafted in and the engine isn't set back as far as it could be. The mounts are welded in, quite well, I might add. Looks like he's stuck with fan clearance issues. Far as the fix, I'd try a higher cfm fan first and if it helps some but not enough, the start looking into a radiator with more efficiency. Just my opinion though. AREA51 would be a cool license plate on a '51. olnolan
  #20 (permalink)
Old 06-09-2010, 11:16 PM
Wiki Edits: 326
Another bungled swap. I wish I had a nickel......
As I said in another thread, I just don't go out to the amateur car shows like I used to. I can't stand looking at the butchered cars any more.
  #21 (permalink)
Old 06-10-2010, 12:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Somehow I doubt the car is bungled OR butchered by what I could tell from the photos. Just needs sorted out, seems more likely.
Area51, I didn't see any engine bay shots in your photo gallery- if you could either post a few or point my tired eyes to the page they're on, I'd appreciate it.
  #22 (permalink)
Old 06-10-2010, 02:51 AM
Wiki Edits: 326
You have your opinion and I have mine.
As a result of my 50+ years of hot rodding, It is my opinion that if you don't have room to put a mechanical fan arrangement into a '51 Chevy with a SBC, then the installation was bungled, as in....done by someone who should have kept their hands in their pockets and had no business trying to put a SBC into a '51 Chevy.
  #23 (permalink)
Old 06-10-2010, 03:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Your damned right I have an opinion- and were I to give it, I'd likely be in trouble w/the moderators.
Suffice to say-in this regard, you don't have enough to go on to say any such thing as "butchered" OR "botched".
But I know that won't stop you, nor should it.
Now, may your many supporters rally to sooth your bruised ego. LOL
  #24 (permalink)
Old 06-10-2010, 03:20 AM
Wiki Edits: 326
Naaah, my ego is fine. All done.
Help! Electric Cooling fan set up. How do you... camaro freak Engine 4 08-19-2007 08:29 PM
electric fan CARGUY Electrical 2 06-12-2006 03:35 PM
Electric or Mechanical fan? Which do you prefer? Z-Money Pit Engine 13 11-15-2005 05:44 AM
Electric Fan Recommendations? Malibu73 Engine 18 06-01-2005 03:26 PM
Why does fuel pressure drops when electric fan turns on Palmtrees57chevy Engine 34 03-31-2005 11:47 PM
