-   -   Electric Fan (http://www.hotrodders.com/forum/electric-fan-220090.html)
billonwheels 06-01-2012 01:15 PM
Electric Fan
3 Attachment(s)
Ok Guys, I've been talked into installing an Electric Fan on My GP. Any ideas on what kind and which brand works best? and does the fan need a switch?
spinn 06-01-2012 01:29 PM
A temperature switch and manual on overide is a good cheap idea. Chose a temp switch that works with your thermostat range.
I like your painted driveshaft.. My truck has a candycane red and white job on it.
billonwheels 06-01-2012 01:33 PM
Thanks, this project has taken on a mind of it own....I'm just along for the ride. I've noticed everything for these PMD engines are pricey :sweat:
75gmck25 06-02-2012 06:58 AM
One of the favorite options in the past was the two speed fan and shroud from the Lincoln Mark 7 or the 90s Ford Taurus or Windstar. You can usually pull all the relays with the fan, and you will need them because these fans have a very high startup amperage. However, they are supposed to work very well to cool an SBC. The original design kicks them in at two temp settings, so you only go to dual fans running if you need it.
Bruce
TommyK 06-02-2012 10:28 AM
Ford Contour dual fan set up. Google it.
