Electric Fan - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2012, 01:15 PM
billonwheels's Avatar
Last journal entry: On the Road
Electric Fan
Ok Guys, I've been talked into installing an Electric Fan on My GP. Any ideas on what kind and which brand works best? and does the fan need a switch?
ID:	65752   Click image for larger version
ID:	65753   Click image for larger version
Old 06-01-2012, 01:29 PM
A temperature switch and manual on overide is a good cheap idea. Chose a temp switch that works with your thermostat range.
I like your painted driveshaft.. My truck has a candycane red and white job on it.
Old 06-01-2012, 01:33 PM
Thanks, this project has taken on a mind of it own....I'm just along for the ride. I've noticed everything for these PMD engines are pricey
Old 06-02-2012, 06:58 AM
One of the favorite options in the past was the two speed fan and shroud from the Lincoln Mark 7 or the 90s Ford Taurus or Windstar. You can usually pull all the relays with the fan, and you will need them because these fans have a very high startup amperage. However, they are supposed to work very well to cool an SBC. The original design kicks them in at two temp settings, so you only go to dual fans running if you need it.
Bruce
Old 06-02-2012, 10:28 AM
Ford Contour dual fan set up. Google it.
electric fan Bracewell Engine 15 10-28-2010 12:04 PM
electric fan ? Area_51 Engine 23 06-10-2010 03:20 AM
Electric Fan Chevy 84 Electrical 7 05-04-2008 06:48 AM
Electric Fan malibuman66 Electrical 4 09-29-2004 11:49 PM
electric fan or clutch fan?? mancinator Engine 4 06-02-2004 02:49 PM
