electric fan - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2012, 01:33 PM
electric fan
I'm building a 39 chevy pickup. I rebuilt a 283 bored 30 over and a mild cam my question is how do I know what electric fan to use? I started to build a shroud but need to know the hole size to cut. I have 17 inches side to side and more than that top to bottom.I was thinking about a 16 in circle cut leaving a little on both sides for mounting.
Old 07-17-2012, 03:29 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Select the fan or fans before cutting anything.
Depending on the dimensions of the radiator the fans should cover as much of the radiator as possible. This will take advantage of the entire cooling core.
Some fans a sold with the shroud and some have just a frame.
Also, electric fans are designed to be pullers or pushers depending if they are mounted in back of (pullers) or in front of (pushers) the radiator.
The fans will need to be controlled by the engine temperature.
vicrod
Old 07-18-2012, 03:54 AM
EOD Guy's Avatar
Get your fan(s) 1st!..... I pulled mine off a late 90's Camaro, two fans, which allows me to have hi and low cooling. I used the Dakata Digital fan controller and am very satisified with it.
Old 07-18-2012, 01:52 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
I heard fans out of a Ford Windstar worked very well.
electric fan ? Area_51 Engine 23 06-10-2010 03:20 AM
Electric Fan Chevy 84 Electrical 7 05-04-2008 06:48 AM
electric fan or clutch fan?? mancinator Engine 4 06-02-2004 02:49 PM
electric fan ? inkfixer73 Engine 2 09-08-2003 04:41 AM
electric fan CARGUY Electrical 5 10-24-2002 01:10 PM
