Electric fan - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2012, 09:14 PM
Jmccrack's Avatar
Last journal entry: Inner Fender problems
Electric fan
So let me ask you all. Because of space problems I need to mount my 16" fan on the front of my Walker Rad. I can reverse the blades to make it a pusher and when I turn it on it moves a lot of air. I have room on the back side of my rad at the the top for a 10", if I mount a puller there do you think it will work? The 16" on the front is near the bottom of the rad because I cannot move it up.
Old 09-03-2012, 11:37 PM
blwn31's Avatar
Can you remove the 16" fan from it's cage and mount it in a custom shroud. This is what I did, and it shrunk the room needed quite a bit. My shroud is slightly deeper at the top than the bottom. I ended up using a 14" and a 10" fan in my custom shroud. My shroud is 1.125" deep on top and .750" deep on the bottom and the fans are mounted inside the shroud. This puts them pretty close to the radiator. My car has an all aluminum blown 406. I have not had any overheating problems even when the temps are in the 100 degree range in traffic, 190 degrees all day long. I to am running a Walker radiator. I know I didn't answer your question directly, just wanted to let you know there are options. I don't particularly like pusher fans, they can cause flow problems through the radiator at cruise speeds.
Keith
Electric Fan billonwheels Hotrodding Basics 4 06-02-2012 11:28 AM
electric fan Bracewell Engine 14 10-28-2010 01:04 PM
Electric Fan malibuman66 Electrical 4 09-30-2004 12:49 AM
electric fan or clutch fan?? mancinator Engine 4 06-02-2004 03:49 PM
Electric fan? zachscc Engine 4 01-11-2003 09:32 PM
