Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electric Fan
Thread: Electric Fan
Old 05-04-2008, 06:27 AM
justold's Avatar
justold justold is offline
If you want to keep the feature of manual on using one switch change the switch to a double pole double throw center off and wire one side in between the t-stat power and the t-stat . This will give you up manual center all off down t-stat controlled .
