Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electric Fan
Thread: Electric Fan
Old 05-04-2008, 06:38 AM
41willys's Avatar
41willys 41willys is offline
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
Agree with justold.
Yes, "sounds like" the sending unit is not shutting down the circuit. I would go to a three position switch as justold stated, and replace the thermostat sending unit.
To answer your other question, I feel it is o.k. to run just a manual on/off switch. I did this as well, some people disagree, "what if you forget to turn them on?" I have mine set up to turn on the water pump and the fans.
Jason
