Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electric Fan
Thread: Electric Fan
Old 05-04-2008, 06:48 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Another way to skin the cat would be to rewire the hot wire to your thermostat off of a "hot on run" circuit off your ignition switch. That way, when you turn off the ignition there will be no juice to the fan...but when you start up the car you won't have to worry about turning on the fan because the t-stat will flip it on at the designated temperature.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
