Electric Fan CFM - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2012, 01:02 PM
64Joker's Avatar
64Joker
Electric Fan CFM
Planning on installing a "SPAL" 16" puller electric fan on the following application:
Make: Chevrolet
Model: Impala SS
Engine: 327 cui
Trans: Auto
What is the minimum "CFM" speed I should consider to make it worth while?
Old 08-16-2012, 02:09 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
There's no rule of thumb I'm aware of, to me, the highest capacity you can get. I run two 1800 SPAL's and a three core BeCool, fully shrouded on my blower car. It still runs warm on a 100+ degree cruise day. The T-Bucket, BBC has a single SPAL 1800, it also runs warm in traffic as well. It's hard to beat mother nature.
Semper Fi
Old 08-16-2012, 03:49 PM
327NUT's Avatar
As 68Nova said......also don't count on the listed cfm as gospel, believe it or not some mfg. "actually" fib a little on just how much air thier fan moves....can you believe it I bought a rated 2700 (??) cfm Zirgo "S" blade fan years, only used it in the garage when I broke in my 331" sbc and subsequent engine runs but it really did move the air. When you get down to it, how would anyone tell just how close the fan is to the rated cfm?
Old 08-17-2012, 06:11 AM
Last journal entry: Still running strong
Ive read that the fans that pull alot of amps also move alot of air.If you see a fan that has a high cfm rating an a amp rating thats higher than other fans with the same or close cfm then it would be a good bet that fan is more gooder.But then many amps do you want to be pulling? Sorta like picking the witch or the devil.
Old 08-17-2012, 09:04 AM
65 Imp SS's Avatar
Originally Posted by 64Joker View Post
Planning on installing a "SPAL" 16" puller electric fan . What is the minimum "CFM" speed I should consider to make it worth while?
The "Spal 16" is kinda vague statement, if you go to Spal: SPAL USA you see they make a few different styles. Low/ Med profile and High/Extreme performace. I would give them a call and see what they recommend for your app.
Here is a couple of articles that might be of interest:
How to Design And Build A High-Performance Cooling System - How To - Car Craft Magazine
Electric Radiator Fans - Car Craft Magazine
Old 08-17-2012, 11:03 AM
65 Imp SS's Avatar
When setups are space limiting, I've ran with dual elec fans and go with as much size,amps and cfm will allow in fitment, sometimes even staggering their mount position on a aluminum shroud. With higher amp draw you need a large enough alternator ,and wire it accordingly. Have had good results with the Powermaster 140amp alt. I had done an actual amp check on a pair of Maradyne M122 and when started individually they briefly spike up to 40amp each and "settle" to 13.5-13.8 amps running and are rated mid 1500's cfm each. Note in previous post link where Spal's "rule of thumb" is approx 10amps per 1000cfm.
recommended cfm for electric fan for decent 383 stroker my87Z Engine 9 01-28-2010 04:15 PM
Electric Fan CFM dedub Engine 9 04-28-2009 07:07 AM
How much fan cfm for a Chevy SB? staleg Engine 4 12-12-2008 03:30 PM
Flex Fan cfm Full Throttle Engine 12 08-17-2004 06:10 AM
SPAL 2700 CFM electric fan Loup Engine 3 03-29-2004 09:46 PM
