-   -   Electric Fan Crearance (http://www.hotrodders.com/forum/electric-fan-crearance-226780.html)
454 Rattler 12-03-2012 02:08 PM
How close to the radiator fins should the blades or shourd be mounted ? It's a pusher fan going into a 36 Ford with a small block. Theres a very small shroud around the blades.
Thanks, guys !
454 RATTLER
My Spell Check didn't catch the misspelling of the word Clearance in the title !! Sorry about that !
techinspector1 12-03-2012 03:56 PM
Thanks, guys !
454 RATTLER
Just tell 'em you were munching on a brownie when you said it....:thumbup:
Never did what you are proposing. Never needed to because I will only use crank-driven fans. Snow White makes a short water pump for the SBF and it should be possible to mount the radiator a little further ahead with some tinkering.
If I were going to though, I think I'd mount a full shroud on the front of the radiator with two holes in the shroud for two fans. If I couldn't find a commercially-available shroud, I'd fabricate one from sheet aluminum and pop rivet it together.
oldbogie 12-04-2012 01:46 PM
Thanks, guys !
454 RATTLER
Pusher fans lack effectiveness, the area they cover against the total radiator core area is pretty small. The idea with the shroud is to promote some siphon flow around the outside of the shroud by the pressure reduction of the air exiting the fan. This isn't as effective as it needs to be. The most effective set up is a puller fan on the engine side sitting at the exit of a shroud that seals the perimeter of the radiator. This develops a low pressure area behind the core so air flow will occur across the entire surface area. This level of efficiency is not considered visually attractive so is seldom seen on street rods. Cooling of these machines just continues to be a problem.
Bogie
sunsetdart 12-05-2012 05:02 AM
Is this fan labeled as a "pusher" or is it a puller that you turned the blade backwards to make it a pusher?
Reason I say this is you want a true pusher fan like a Spal. They work very well and had one on my 600HP motor for 9 yrs with no problems.
SSedan64 12-05-2012 07:37 AM
Several Dual Fan Shroud styles here >> dual fan shroud kit - Bing Images
With Fans mounted high & low it will give more clearance between the Pulley & Rad.
bob70 12-05-2012 06:04 PM
Wouldn't a shroud on a front mounted pusher fan be counter productive in that it would limit air flow when the car was moving down the road?
454 Rattler 12-06-2012 09:11 AM
Thats what I was thinking too.
This is a new Spal fan. I still need to know how close to mount it to the radiator.
Thanks !
454 RATTLER
bob70 12-06-2012 09:40 PM
I don't know if there's any "rule" on that but I'd get it pretty close being sure to leave enough room to allow for a small amount of flexing and still not hit the radiator. Maybe 1/2 inch?
SSedan64 12-09-2012 08:49 AM
Yes, a shroud on a Pusher would block airflow.
X2, on the mounting clearance, leave room for Blade flex.
1971BB427 12-11-2012 12:31 PM
You don't turn blades on electric fans, you reverse polarity on the leads to change direction.
