According to everything I have read, and done, the most effecient way to mount a fan is on the engine side pulling air through the radiator core. Blowing air through the core from the back is not a good thing, the car will overheat on the road.
If you are putting it on the engine side, I strongly recommend using a shroud to assist the fan in doing its job. Without a shroud on the engine side, electric fans have trouble doing anything more than stirring up under hood air. Mounted on the outside, it is recommended to not use a shroud. As a shroud on the outside will do little in assisting how well the fans push air, and will only block a good deal of airflow when the car is moving. |
I don't know what brand my fan is,but it has about 10 blades and is in its own shroud and has plastic grateing over it so u don't get fingers in it,The whole thing is only about 2" deep and is all plastic
Now I'm wondering if U have to flip the blades over when reversing direction??? Last edited by yragat; 02-19-2007 at 12:11 PM. Reason: flip blade |
It depends on the type of electrical motor is has.
Some will reverse when the wires are reversed. Some will not. So with some, you must remove the blades, and install them to opposite way.
so am I correct in assuming that if I switch the wires and the motor still turns in the same direction then I will have to reverse the blades? Another thing, it's wired to come on at 185 and also anytime the AC compressor comes on.Could I take the wire running from the fan control to the AC and run it to a toggle switch? I'm running a 4 cyl and it don't run hot so I don't see why the fan has to always come on with the compressor
Doc here,
To reverse the direction of a DC Fan motor, (provided it is NOT polarity protected by a diode or cap, ) just reverse the power and ground wires.. The blades on MOST Cooling fans are "Flat" enough of a pitch where they will run equally as well in either direction..so that shouldn't be a worry.. The biggest part is a GOOD shroud that directs air as close to the engine block as practical, and be sure hot air is not cycling around the front of the radiator. (seal the mounting area) AND good air flow OUT of the engine bay for hot air. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Doc here,
Yes it will, If you run it in SERIES with the AC Control wire (cut the wire and install it between the cut wires) . I'd check out HOW hot it really runs with the AC lugging the 4 cylinder engine FIRST before making anything carved in stone..you may find it is a Necessary evil.. Doc
If I do it that way when I flip the toggle switch The fan will come on and still be getting juice from the ACwire,is that right?
If thats the case I wouldn't be able to manually turn the fan on unless the compressor is running.(I think) what I want to do is be able to manually turn the fan on at any time |
Doc here, OK, I thought you wanted to be able to turn it OFF manually in AC mode..sorry my bad.. If that's the case, Find your Temp switch controller for the fan. Determine if it switches ground (Traditional) or power (non conventional)...Just for grins, assume it's ground. Hook the Center wiper of your switch to a good , properly bonded ground. The normally open side will go to the FAN MOTOR side of the switch (or the relay coil side of the switch, if using a relay). In this configuration, it will turn ON any time you flip the switch. Doc
| Electric cooling fan | Z-Money Pit | Engine | 1 | 08-29-2006 08:27 PM |
| Need advice on a good electric fan set up. | Streetmaster | Engine | 13 | 01-07-2006 02:37 PM |
| ? about an electric fan for PU. | Streetmaster | Engine | 8 | 08-20-2005 10:14 PM |
| TPI electric Fan HELP! | boneyard Buick | Engine | 4 | 07-31-2005 12:21 PM |
| electric fan or clutch fan?? | mancinator | Engine | 4 | 06-02-2004 02:49 PM |
