Electric fan front and back - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2012, 11:36 AM
Jmccrack's Avatar
Last journal entry: Inner Fender problems
Hey guys question. We have talked before about this but here is another thought. I am building a 34 Ford with a ZZ383 and air. Because of the engine placment I have no room to put my 16" electric fan behind the rad, so in front it goes! Now because of the grill shell I can only put the fan down at the bottom of the rad ( not the best place I know). So here is my question I have a 16" pusher in front of the rad at the bottom, is there any reason I could not put a 10" puller behind the rad at the top, the two do not interfere with each other,well maybe by an inch or so. I guess my main conceren might be amp draw. Any thoughts
Old 09-11-2012, 05:47 PM
Proud LOSER
Hey, I'm about to do the same thing with my beater Vette....so I'm kinda curious to hear some replies
Old 09-11-2012, 06:35 PM
I see no reason not to do it. You, of course, already realize it is not the best scenario but the whole idea is to move air through the whole radiator. As you mentioned be sure you have ample circuit protection for the current draw.
Old 09-11-2012, 08:56 PM
302 Z28's Avatar
Why not use a Zipps water pump riser? I have one on my 34 Ford with a GM Performance Parts Fastburn 350 w/Walker radiator and it never overheats even in 100+ Texas heat. Deuce on this Forum has one on his 430HP Fastburn also.
Uses a standard Chevy six cylinder water pump and has integral alternator and A/C mounts.
Vince
Electric fan's ? monzter Electrical 14 02-23-2013 09:05 PM
Electric Fan 46_stvblt Electrical 8 01-09-2006 04:19 AM
? about an electric fan for PU. Streetmaster Engine 8 08-20-2005 11:14 PM
electric fan or clutch fan?? mancinator Engine 4 06-02-2004 03:49 PM
electric fan ? inkfixer73 Engine 2 09-08-2003 05:41 AM
