Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - electric fan heat sensor
Old 02-06-2013, 03:38 PM
delawarebill's Avatar
delawarebill delawarebill is offline
temp probe
Originally Posted by orlando295 View Post
i do have one on the front but my temperature gauge is hooked up there do think i can move temperature gauge to head area and then install heater sensor in front will my temperature gauge read right?
yes u can.. the temp will be a little diff from the stat area to the head area. i had an old tunnel with no port for a temp probe and used the head area.. changed intake and went to the stat area. but bottom line is yes u can us it.. might consider using the lower hose fitting too.. that is a nice idea.. or cut the upper and install there too...
