electric fan problems - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-30-2010, 06:51 AM
302 Z28's Avatar
Vince
  #32 (permalink)
Old 11-30-2010, 07:02 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
pushers are for a/c only. they do not work for cooling. put it on the pull side and reverse the wires. blade may or may not need changing .
  #33 (permalink)
Old 11-30-2010, 09:25 AM
Originally Posted by ericnova72
Yep, I agree also^^^
this is assuming the blades on the fan are capable of operating in reverse.. some are.. some aren't.
my big fan I run can run either way.. the small fan can't..
  #34 (permalink)
Old 11-30-2010, 02:05 PM
life is a temporary assignment
There is only one way for sure to find out.. Hook the fan to a battery in find out.. Switch the wires in see what happens.. Then ''YOU'' will know if it will work or not..
  #35 (permalink)
Old 11-30-2010, 03:56 PM
ah.. but see.. the fan will likely move air in reverse, even if it "can't" .. it will just do so at significantly reduced efficiency, and possibly much more noisy.
Do you have the instructions that came with the fan? or is the fan a used unit?
  #36 (permalink)
Old 11-30-2010, 05:39 PM
I won't be able to check the wiring on the fan for a few more weeks, since the car is stored a different location then I am, but I will let you guys know how the final verdict came out. Thanks Again for all your insite and knowledge. Happy Holidays!
  #37 (permalink)
Old 11-30-2010, 05:41 PM
Same to you and your family.. Good luck, And hope you have a blessed one...
  #38 (permalink)
Old 12-19-2010, 11:56 PM
electric fan
I reversed the wires and polarity changed and now works perfect, but I do want to fabricate an aluminum shroud. Pls if anyone has some pictures of one they have done in the past would be appreciated. Thank you to all you guys for all your insite.
  #39 (permalink)
Old 12-20-2010, 03:45 AM
EOD Guy's Avatar
I'm glad you got it working, in the end that's what it's all about.
  #40 (permalink)
Old 12-20-2010, 03:56 AM
EOD Guy's Avatar
As far as a battle, as posted by new interiors, look back at the posts..... caps mean nothing except to place emphasis on your particular point of view, and that is exactly what it was your take on things. I agree pulling air through the radiator is the preferred method (never said different), however why did several manufacturers make pusher type fans?
  #41 (permalink)
Old 12-20-2010, 07:26 AM
Great to hear you have it.. If your going to build a shroud.. Make sure you leave about 3/4'' between the shroud and rad.. I hope you have it on the inside pulling air, A shroud won't work good on the outside.. I wish I would have took pictures of the one I made for my 41 willys.. Came out really nice.. Anyway.. Great news And good luck..
Look through here.. This will give you some idea's..
http://www.google.com/images?um=1&hl...=&oq=&gs_rfai=
  #42 (permalink)
Old 12-20-2010, 07:30 AM
I think shine gave a very good answer here..
  #43 (permalink)
Old 12-20-2010, 11:45 AM
fan
it is installed on the pull side of the radiator, and seems to be drawing a larger amount of air through the radiator, but i am sure a shroud would make it even more effficent.
  #44 (permalink)
Old 12-20-2010, 12:24 PM
Yes they do help..
I have done some without the shroud, And had no problem.. If the motor isn't to hot, And you don't have a big stall.. You can sometimes get by without one.. You will know for sure on a hot day.. Test it..I had about five cars that never had a shroud, And over 100* days here down south.. Never got hot.. But If you can make one I would..
buy a new fan or use ford taurus fan daveid Hotrodding Basics 23 10-22-2009 07:38 PM
Electric fan wiring? Boostedpimp Electrical 13 12-12-2006 10:44 PM
Need advice on a good electric fan set up. Streetmaster Engine 13 01-07-2006 02:37 PM
Clutch Fan malibuman66 Engine 18 01-01-2005 10:09 AM
Electric fan, pusher, puller 39chevy General Rodding Tech 2 04-30-2004 08:14 PM
