Electric fan question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2010, 07:11 PM
Mikeymuy's Avatar
Ok iam lookin into a new electric fan since i got a new speedway radiator and my old setup is too big what cfm and size should i look for its for an off-road truck sand dunes sand drags and a Lil city driving? iam workin wit 19'tall 31"width radiator.. thinkin bout a fan shroud kit
Old 08-22-2010, 08:19 PM
LATECH's Avatar
Are you going to put the fans on the front (pushers) and run the fan on the water pump also?then a shroud is ok.If you are going to m ount them as pullers (engine side of radiator) then no shroud.
Aternate the posistion of the fans you know top left - bottom right or top right - bottom left. Diagonally works best because you can cover more area. put them closest to the water inlet and to the outlet.get the most cfm fan you can fit in there.I dunno, do they make a full shrouded electric fan setup that isnt like a one motor one blade oem pos?Something with directional flaps that would allow airflow while moving and not while at a light when the fan was on?
Old 08-22-2010, 08:29 PM
68NovaSS's Avatar
Wiki Edits: 9
Whether you run the fans as pushers along with the WP fan or as pullers (most efficient), you need to have a shroud, either as part of the electric kit or OEM/fabricated.
Old 08-23-2010, 04:56 AM
SSedan64's Avatar
Find a Lincoln Mark VIII & get the fan or new on Ebay. These work better than most all aftermarket fans. Intrepid fans work well also.
Fan & wiring Info here.>> http://www.montecarloss.com/communit...&Number=817861
Old 08-23-2010, 08:02 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
I usually go for the most cfm's I can. and make a shroud..
Old 08-23-2010, 08:29 AM
GTXKen's Avatar
Even the best fan is not going to do well without a shroud.
Check out an HHR fan setup, they are pretty cheap for a dealer part and pull a ton of air. Lots of big block mopar guys use them. I think the whole deal is not much more than 5" thick but please don't quote me.
Electric Fan wiring Blue67Camaro Electrical 9 03-17-2008 05:56 PM
Electric fan wiring? Boostedpimp Electrical 13 12-12-2006 10:44 PM
Electric Fan 46_stvblt Electrical 8 01-09-2006 03:19 AM
Why does fuel pressure drops when electric fan turns on Palmtrees57chevy Engine 34 03-31-2005 11:47 PM
electric fan or clutch fan?? mancinator Engine 4 06-02-2004 02:49 PM
