Electric fan sensor mounting. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2010, 07:33 PM
cboy's Avatar
Last journal entry: Finished
The wiring kit with my Perma-Cool electric fan is one of those external modules which is mounted on the outside of a radiator hose using a tie wrap. I've got a similar sensor on my roadster and I've never been able to get it mounted well enough to work properly or consistently. And the one I have for the sedan delivery isn't working either. Among other things, when the engine heats up, the tie rap plastic gets soft and the contact between the sensor and the hose loosens up considerably.
Short of another wiring kit with an internal sensor in the block or head, has anyone devised a way to attach one of these sensors so that it is reliable?
Always learning...and sharing what I've learned.
Old 05-19-2010, 07:51 PM
302 Z28's Avatar
What about some of that heat resistant/conductive glue, then you could might glue it to the side or top of the radiator?
Vince
Old 05-19-2010, 08:01 PM
cboy's Avatar
Good thought. My only concern would be that it might be a bit too "permanent". If it didn't work, for some reason, could the glue on the sensor render it unusable for another type of mounting experiment. But then, if others chime in who have done it this way with good success, then I'd be willing to give it a shot.
Old 05-19-2010, 09:03 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I would think this would be cleaner looking and a more direct and accurate way to control a fan and water temp. The sensor would be in the block/manifold and in the water path .
http://www.speedwaymotors.com/Electr...nsor,2349.html
Old 05-19-2010, 09:20 PM
cboy's Avatar
Yes, as noted in my OP, I'm fully aware of the "in block" sensors. But my question was, short of buying one of those, what ways have people found to reliably mount THIS sensor. It's the one that came with my fan/wiring and it is the one I have. If no one has ever been able to mount one of these so it works, then maybe I'd consider an alternative. But for the present, I'm just looking to make this one work.
Old 05-19-2010, 09:30 PM
pepi's Avatar
understood I just go for bullet proof myself, obviously the method that painless has is not so great . Considering that you also mention that the other hotrod has the same hook up that sometimes does not work "properly or consistently" the block sensor will 100%
Old 05-19-2010, 09:36 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Have you talked to Permacool's Tech Support?
Hopefully you don't get the "Dang, that's the first we've heard of that!" response.
Old 05-19-2010, 09:42 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
can you use a hose clamp instead of zip tie to mount it on the hose?
Old 05-19-2010, 09:52 PM
pepi's Avatar
If it is one of those flat probes i have seen them slipped in under the radiator hose and the the clamp is run down so it dose not leak . Less ugly then clamps all over the place .. you took a long time to build a clean ride do not muck it up with the wiring .
Old 05-20-2010, 06:06 AM
cboy's Avatar
...If it is one of those flat probes i have seen them slipped in under the radiator hose
Unfortunately, this is the much taller style...about 3/4"-1" high. So it's pretty obtrusive.
Old 05-20-2010, 10:45 AM
In my '48 Dodge with a '85 318, I had a set up with a probe tyhat stuck in between the fins in the radiator. Was not a very good system ! Went thru 2 control units in 2 years ! Finally made my own .... As I have a short lenght of metal pipe in the top rad hose, just after the curve comming out of the thermostat, so the pipe is level , (befor it gets to the rad ) , installed switch (grounding type ) in the bottom of the short piece of pipe, so when the thermostat opens, the hot water crosses the switch , gcompletes the circut, and then grounds the relay on the fender. The relay is just a regular square relay found on many cars , just wire it in .....simple and easy.
Old 05-20-2010, 11:08 AM
Last journal entry: 50 Ply wagon
I have seen metal(aluminum) tie wraps. I would try checking out the web and you may find a place that carrys them.
Help! Electric Cooling fan set up. How do you... camaro freak Engine 4 08-19-2007 08:29 PM
electric fan CARGUY Electrical 2 06-12-2006 03:35 PM
Electric or Mechanical fan? Which do you prefer? Z-Money Pit Engine 13 11-15-2005 05:44 AM
Electric Fan Recommendations? Malibu73 Engine 18 06-01-2005 03:26 PM
Why does fuel pressure drops when electric fan turns on Palmtrees57chevy Engine 34 03-31-2005 11:47 PM
