-   -   electric fan setup (http://www.hotrodders.com/forum/electric-fan-setup-219683.html)
Camaro820 05-21-2012 09:32 PM
electric fan setup
hey guys. on my 84 camaro, i was wondering if it would be better to set up my fans to push in air, or the pull the cool air in? a couple people told me to push the air in wouldnt do any good because of how the front nose of the car is.
327NUT 05-21-2012 10:12 PM
If you're going to use electric set it up with a puller fan(s).
bracketeer 05-22-2012 01:40 AM
fan blades
if your worried about cooling
you can use a dual fan set up
straight blades move more air but are noisier
blwn31 05-22-2012 02:45 AM
With electric fans, whenever possible, you want to use puller/s.
Keith
John long 05-22-2012 09:01 AM
Ditto to all of the above. Using a shroud will double the effiency of the puller by drawing air in across the entire radiator.
Camaro820 05-22-2012 09:28 AM
Thanks guys! I will set up the fans to pull! Much appreciated!
malc 05-22-2012 11:54 AM
Is your spoiler under the front still in place, absolutely necessary when moving ?
Camaro820 05-22-2012 11:56 AM
Yes it's still there.
malc 05-22-2012 12:27 PM
I made a box shroud and placed two fans on it to cool my 86 Camaro.
http://www.hotrodders.com/gallery/da...hroud_Left.JPG
And cobbled up a new air dam.
http://www.hotrodders.com/gallery/da...m_right_II.jpg
http://www.hotrodders.com/gallery/da...am_Left_II.jpg
Camaro820 05-23-2012 08:23 AM
Wow that looks really good, man. I might have to try something like that.
russ69coupe 05-23-2012 05:13 PM
Yeah, if that is cobbled up I would really like to see your "good" work. :thumbup:
Russ
Rickracer 05-24-2012 08:30 AM
98 and up Intrepid fans work great, and are what a lot of V8 S10 guys are using. Here's a shroud idea a lot of folks can use: Baking Pan/Cookie Sheet Fan Shroud :cool:
