electric fan setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2012, 08:32 PM
Camaro820's Avatar
electric fan setup
hey guys. on my 84 camaro, i was wondering if it would be better to set up my fans to push in air, or the pull the cool air in? a couple people told me to push the air in wouldnt do any good because of how the front nose of the car is.
Old 05-21-2012, 09:12 PM
327NUT's Avatar
If you're going to use electric set it up with a puller fan(s).
Old 05-22-2012, 12:40 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
fan blades
if your worried about cooling
you can use a dual fan set up
straight blades move more air but are noisier
Old 05-22-2012, 01:45 AM
blwn31's Avatar
With electric fans, whenever possible, you want to use puller/s.
Keith
Old 05-22-2012, 08:01 AM
Ditto to all of the above. Using a shroud will double the effiency of the puller by drawing air in across the entire radiator.
Old 05-22-2012, 08:28 AM
Camaro820's Avatar
Thanks guys! I will set up the fans to pull! Much appreciated!
Old 05-22-2012, 10:54 AM
malc's Avatar
Born To Be Mild
Is your spoiler under the front still in place, absolutely necessary when moving ?
Old 05-22-2012, 10:56 AM
Camaro820's Avatar
Yes it's still there.
Old 05-22-2012, 11:27 AM
malc's Avatar
Born To Be Mild
I made a box shroud and placed two fans on it to cool my 86 Camaro.
And cobbled up a new air dam.
Old 05-23-2012, 07:23 AM
Camaro820's Avatar
Wow that looks really good, man. I might have to try something like that.
Old 05-23-2012, 04:13 PM
russ69coupe's Avatar
Last journal entry: starting to go the right direction
Yeah, if that is cobbled up I would really like to see your "good" work.
Russ
Old 05-24-2012, 07:30 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
98 and up Intrepid fans work great, and are what a lot of V8 S10 guys are using. Here's a shroud idea a lot of folks can use: Baking Pan/Cookie Sheet Fan Shroud
Decided to try the electric fan route..what would work for my setup..any ideas?? redfish211 Engine 3 08-08-2011 05:03 PM
Electric Fan Setup zildjian4life218 Engine 5 04-22-2011 08:33 PM
Electric Cooling Fan control setup 76_TA Engine 11 09-01-2010 07:13 PM
Electric Dual Fan Setup stfinney Engine 23 05-25-2008 11:15 PM
SBC electric fan setup... Sagacious Engine 5 08-11-2004 06:29 AM
