Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electric Fan-Shroud or no Shroud?
Old 02-05-2009, 10:54 AM
Cole's Avatar
Cole Cole is offline
Now if I could just afford Gas
Last journal entry: Breaking Bad on the Camaro
Well the problem is that it is gettting warmer (220+) than I would like to see. It's fine on the freeway but if I am on surface streets it does get warm unless I stay off the pedel. I had to take the engine and transmission out last last night to address another problem so I thought this would be a good time to consider installing a shroud. It's been in the 80's here but in the summer we are looking at 100+ on some days. I guess this should be a no-brainer but I am also considering a larger radiator too or maybe both? I guess I should just start with a shroud and see how it goes?
Is there a kit so I can make a custom one for may configuration and if so who sells them?
