Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electric fan temp ?
Old 01-13-2013, 10:37 AM
cadillacdave1 cadillacdave1 is offline
The Hayden after market unit works well. It is the heavy duty fan controller and sells for about $50 from Advance/Discount Auto. If you have a problem they will return it. I have had mine on my car several years with no problems. It turns my fan on at 180* and turns off at 165*. It has a simple dial you turn with a screw driver to set when the fans turn on and off. It is fairly simple to install. Just keep an extra relay in the car if the relay ever goes bad.
