Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electric Fan Temp. Sensors
Old 03-30-2004, 03:51 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
If the fan temp switch is mounted in the side of the head, that area will be hotter than if it had been mounted in the intake.
Example Only: Coolant Temp in cylinder head is 210.
Coolant Temp in intake is 180.
The temp difference you are seeing seems to be on the extreme side; but if the two senders are not mounted in a similar location you will see a difference in the readings.
