electric fan temp switch g.m. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2012, 09:17 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
Hello all,
not sure if this question should be here or in the engine area..
I am installing an electric fan in my 71 c-10.. and tho. painless makes a kit, It's just a relay and a temp switch and wire..
looking for a temp switch that closes(on) at 190-195* and opens at 180*(off)
was thinking a mid eighties f body but can't find the specs of when it turned the fans on and what temp it shut them off.. maybe a 94 b body?
any help.. thanks..
Old 01-27-2012, 11:06 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
For what it is worth, I equipped my 72 C10 with the flexalite variable speed fan controller. You cant beat this, a bit more cash but well worth it and it has operated flawless for years:
http://www.flex-a-lite.com/auto/31165-99943.pdf
Modulating soft start control is also easier on the fan motor, just to name one benefit
Old 01-27-2012, 02:57 PM
stich626's Avatar
gearheadslife
thats nice,, but 99.00 I'm doing the jeep fan in the c-10 scroud,, the fan new was 59.00 from mother mopar.. maybe if I was installing a costly fan.. the thermal switchs are 39.00 new.. I'll do that if I can't find a stock part that I can get at a junkyard crawl.. no point is spending money,(real money) till I know what engines going in this down the road.. will it be a 355 or 496, both are on hand,, if this truck stays d.d. duty, it'll get a g.m. crate 96-02 truck vortec.. moneys an issue, as I'm out on medical leave from work.. so cheap is good..
thanks at least it gives me options
Old 01-27-2012, 04:12 PM
Custom10's Avatar
Roger that
Old 01-27-2012, 04:57 PM
LATECH's Avatar
Google "Derale" , they make a few products that may work.
Old 01-27-2012, 08:15 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Summit Racing has what you need.
Don't forget the use a 180* thermostat.
vicrod
Old 01-28-2012, 07:21 AM
EOD Guy's Avatar
While costly, the Dakota Digital unit is a very solid unit. I like the fact that I have a test mode..... it allows me to turn the fans on/off etc....... giving me a piece of mind that fan one is coming on when it should then fan two etc...... I am ver pleased with mine.
Electric Fan Temp. Sensors horvath Electrical 26 04-26-2011 04:04 PM
Temp switch for electric fan solidaxel Electrical 2 03-05-2005 01:31 PM
electric fan temp switch probe, problem 39chevy Electrical 3 08-07-2004 08:28 PM
electric fan (Adjustable temp switch) QUESTION 39chevy Electrical 0 06-16-2004 08:54 PM
temp switch Trav Engine 3 02-02-2004 08:10 PM
