electric fan thermostat - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2012, 05:30 PM
Hello, Does anyone know what the best thermastat for electric fan (screw in type )or the probe that goes in radiator fins also if you use screw in type can you also hook temp gauge wire to that sending unit Thanks,Michael
Old 10-18-2012, 06:17 PM
delawarebill's Avatar
T-stat sw
u can't use the stat switch to run your temp gage. if u have a sbc and want to run the fan sw and temp sensor?? use the front outlet of engine hole for the switch and on the passenger side between the middle cyl's is a 1/2" (i think) plug u can use for the gage sender.
Old 10-18-2012, 06:42 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
A device made by Centech Inc. model # FC-2PG is designed to connect to an electric temperature gauge to control the radiator fan.
The unit is adjustable. When the desired temperature us reached it will turn on the fan and off at a lower temperature.
It can also be controlled by an AC system pressure switch to run the fan.
vicrod
Electric Fan switch/Thermostat Combo Southpaw57 Engine 3 05-31-2012 02:32 PM
Electric fan thermostat on / off temp? Chucky5150 Engine 7 04-14-2012 10:17 AM
anyone recommend a thermostat for electric fan? Studedean Electrical 4 01-12-2012 12:19 AM
Electric Fan and thermostat Solidus Engine 9 04-15-2006 09:50 AM
Electric fan thermostat Novaman78 Engine 4 01-27-2005 01:32 AM
