Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electric fan thermostat on / off temp?
Old 04-13-2012, 07:02 AM
65 Imp SS's Avatar
65 Imp SS 65 Imp SS is offline
I have been running the Derale 16789 a Dual fan High-Amperage Adjustable Fan Controller
The Derale High Amperage Adjustable Dual Fan Controller is designed to
operate two electric fans at different activating temperatures. Fan #1 is
designed to activate at the desired adjusted temperature (150 -240F).
Fan #2 will activate once the vehicle water temperature increases by 10F.
The fans will deactivate 10F below each turn-on temperature.
This unit is designed to control 2 electric fans with a
Maximum Draw of 35 Continuous Amps Per Fan.
