Electric fan's ?
Hello fellow hotrodders. I am having trouble to decide what's the right electric fan for me...
The main reason i don't know what to choose is because i am very limited to fan thickness, if i remember correctly max thickness i can run is 2.3/4"
I'm not sure what the size is on the radiator but i can measure it if you would like.
Here's the question, should i aim for a small (diameter) fan with lots of flow (cfm) or take a bigger diameter fan with a bit smaller flow rating ?
I'm going to run a electric water pump so this is going to be the only fan i'm going to use...
Best regards...
Take care.
