if your fan is on the grill side you are going to run a pusher style fan and as barnescole said pullers are more effective. do you have any more information about what you are trying to do? what kind of vehicle is it? fan shroud no fan shroud, does it have an air damn. what type of radiator do you have. there is a lot that goes into choosing your fan and you cooling system setup. if your radiator is mostly square then one large fan may do the trick if its rectangular then two smaller fans may be needed. give us a little more info on what your putting it in and what you will be doing with the vehicle and we can help you a little better.
