Electric fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2008, 05:29 PM
Electric fuel pump
Hi
I'm in the process of putting a 350 in my 26T. It had a 4 cyl with one of those little square elec fuel pumps, I forget what brand,but Mr Gasket makes one . Are those type pumps OK to use with a mild 350? If not what kind of elec pump is recomended with out cleaning out the bank acount? Also how close to the tank should it be and should a filter be before or after the pump?.Do they all need a regulator?
Thanks
Old 03-16-2008, 08:33 PM
The little one probably won't give enough flow a holley red pump will work with out e reg I beleive.
Old 03-16-2008, 08:45 PM
I've been told that the holleys are very noisy, how are the carters?
Old 03-16-2008, 11:42 PM
techinspector1's Avatar
Wiki Edits: 326
All of 'em are noisy if you bolt 'em to the frame or sheetmetal.
http://www.crankshaftcoalition.com/w...uel_Pump_Mount
Put a filter between the tank and the pump and another one just before the carb inlet.
Holley will take 6 lbs max, Edelbrock likes 5 1/2 max.
Old 03-17-2008, 06:46 AM
Thank you
My tank will be in the trunk and the fuel line comes out of the top of the tank with an-8 fitting should I mount the pump in the trunk or down on the frame? Will it hurt to use the an-8 line to the pump and then 3/8 out of the pump? I'm surprised to see a filter before the pump I always thought they went after the pump?
Electric Fuel Pump question. GCD1962 Engine 5 08-06-2007 09:14 AM
electric fuel pump oetken Engine 10 07-31-2007 03:57 PM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
Replacing in tank electric fuel pump scot Hotrodding Basics 6 01-21-2006 01:40 PM
electric fuel pump slammer10 Engine 4 10-26-2001 05:08 PM
