Electric fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2008, 07:03 AM
68ss's Avatar
jackleg
Electric fuel pump
Not having any issues, just wondering what the usual life expectancy of an electric fuel pump is? I have a 2001 Silverado with 78,000 miles on it. I was thinking about replacing it before it leaves me stranded as it is my daily driver.
Thanks
Toby
Old 10-29-2008, 08:27 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Being that you are talking about a GM, I am surprised that it has made it that many miles . I have replaced many GM fuel pumps, some with less miles, some with many more miles than you are talking about. The call has to be yours, but it is a good question. I do suggest that you buy a GM/Delco fuel pump assembly when you do replace it, I have had nothing but bad luck with the aftermarket ones.
Just my .02
Steve
Old 10-29-2008, 09:12 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I think it really depends on how well you maintained the Fuel Filter (by the way, did you know that the new GM Gas Pickups don't have a Fuel Filter?)-one of my Sons has my old 2000 Yukon, it has about 230,000 Miles on it and still drives like new (and gets 21 mgp)-we have always replaced the Fuel Pumps at 100,000 Miles whether they needed it or not (with GM Pumps)-
If it were mine, I'd replace the Fuel Filter and go 100,000 then replace the Pump-
Old 10-29-2008, 09:37 AM
68ss's Avatar
jackleg
Thanks for the heads up. I haven't had any problems but I don't want to either.
Is it easier to pull the bed or drop the tank to change the pump?
Toby
Old 10-29-2008, 09:42 AM
SSedan64's Avatar
I thought those pumps were mounted on the frame rail. I may be wrong tho'.
Old 10-29-2008, 09:50 AM
They are in the tank . I have a 99 silverado and my son has a 2000 . The 99 has 50k and the 2000 has 160k . Fuel light comes on on both. Ill just wait til they quit then pull the bed . six bolts if i am right .
Old 10-29-2008, 10:17 AM
35WINDOW's Avatar
Here at work they drop the Tank-
Old 10-29-2008, 10:22 AM
1931 steve's Avatar
Wiki Edits: 4
That's what I do also.
Steve
Old 10-29-2008, 01:49 PM
cope's Avatar
i have seen gm's with 5 miles on them and the fuel pumps go out my moms mailbu went about 10000 my bosses hd2500 went about 120000 but its just all depends if u run regular i would change the fuel filter every 15000 miles gm says thats the main reason they go out is cause the filter clogs and works the pump too hard but i dont buy it thats how they make there money fuel pumps and steering shafts.
also its is much much easier if u just drop the tank and change it i watched my boss do it out in the hay field in 30 min or less with a full tank
Old 10-29-2008, 02:12 PM
techinspector1's Avatar
Wiki Edits: 326
Depends on whether you'd rather stand up and do it with a hoist or lay down and do it without one.
electric fuel pump question sexypizzaman Engine 26 05-19-2015 07:13 AM
Carter Electric Fuel Pump ID? BT74 Engine 3 05-12-2008 06:49 PM
electric fuel pump oetken Engine 10 07-31-2007 03:57 PM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
Replacing in tank electric fuel pump scot Hotrodding Basics 6 01-21-2006 01:40 PM
