electric fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2009, 10:21 AM
electric fuel pump
What p.s.i. and g.p.h. electric fuel pump do I need for a 389 Pontiac with Tri-power? I'm thinking 7 p.s.i. and 97 g.p.h. max. with no pressure regulator. Anyone agree....disagree?
Old 02-23-2009, 10:56 AM
techinspector1's Avatar
Wiki Edits: 326
7 psi may overpower the needle and seat, allowing fuel to push past them and flood the carb/motor. I don't like to use over 5 psi. There's just no reason to. Run 1/2" lines so you keep the volume up and the pressure low. This pump would be plenty and then some in my opinion....
http://store.summitracing.com/partde...5&autoview=sku
electric fuel pump question sexypizzaman Engine 26 05-19-2015 08:13 AM
Carter Electric Fuel Pump ID? BT74 Engine 3 05-12-2008 07:49 PM
electric fuel pump oetken Engine 10 07-31-2007 04:57 PM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 01:39 PM
Replacing in tank electric fuel pump scot Hotrodding Basics 6 01-21-2006 02:40 PM
