electric fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2011, 11:12 PM
electric fuel pump
Hi everyone, I would like to know if the aeromotive 1000 is a good fuel pump to use with my 540 BBC when I mount my 671 gmc blower, I will be running two QFT 750's and not quite sure which regulator to use with this setup. I've gotten mixed reviews about having a return line to my fuel cell. Is there a better fuel pump than the aeromotive and has anyone had any problems with there's. My pro-street pickup will mostly see street duty and occasional blasts at the strip just to see what she will do and have fun in the process.
This is what she has in her:
Forged steel crank with double key ways
8.5 static compression- light weight Ross Blower pistons full floating
H-beam rods with ARP rod bolts
Rectangular heads with pocket porting
1.7 roller rockers
Home made 2.25 headers with 3.5 inch collector, I couldnt find anyone that made headers this size for my 73 pickup so I made my own equal length headers and had them air craft coated inside and out.
Turbo 400 with 3000 stahl and 4.11 gears in a 9 inch narrowed rear.
Lunati Hyd .236 int .246 exh .553 int .571 exh
You guys have helped me before and I consider your words as Gospel. Thanks guys and girls. I will up load an image soon.
Old 11-20-2011, 07:04 AM
You will need the aeromotive fuel pump controller for the aeromotive fuel pump if you plan to drive it on the street. The controller reduces the voltage to the pump during street use.
Old 11-20-2011, 07:42 AM
delawarebill's Avatar
fuel pump on craigslist
i just say one posted on c/l... don't know how much they are but this one was mounted and not used for $500 bucks...
go to "delawarecraigslist" and in the search block at left insert "2711256400" ... just might help ya....
Old 11-20-2011, 09:52 AM
fuel pump
thank you,
i will look it up, jeff
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Quick Fuel 30-125 125 GPH Electric Fuel Pump 64gto71cobra Engine 1 04-27-2011 11:25 AM
electric fuel pump k.c. Hotrodding Basics 1 02-23-2009 09:56 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
