Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 07-04-2004, 09:43 AM
gto401's Avatar
gto401 gto401 is offline
gto401
Electric fuel pump
I've got a '85 T-Bird with a 302 fuel injected throttle body (I think that's what it is ) anyway the battery went dead, now I can't get any power to the fuel pump. I pulled the tank off an the pump out an hooked it to a battery an it works, I thouht it could be the fuel inertia switch but it wasn't tripped, so I hooked 12 volts to the pump , it pumped like it should an got fuel to the carb. but the injectors won't spray any fuel when I try to turn it over. Can anyone give any suggestions on this problem?
Old 07-04-2004, 11:09 AM
60convert 60convert is offline
relay
find the fuel pump relay and see if it has power coming from the ign. switch if so then see what happens if you swap it with a similiar realy like the horn relay.
Jesse
Old 07-05-2004, 07:00 AM
gto401's Avatar
gto401
electric fuel pump
Where would the fuel pump relay be
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
