Electric Fuel Pump on 68 Camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2010, 09:03 AM
Curtis
Last journal entry: Engine Bay
I have a 68 Camaro in which I am about to install a electric fuel pump. The tank is in the original location. My question is where is the best location for the fuel pump. I know some of you Camaro guys out there has done this before. ---- Go to Curtis Thornton 68 camaro in projects journal and check it out
Old 06-18-2010, 10:27 AM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
Electric pumps are pushers not pullers so the closer to the tank the better. Also, it should be lower than the tank or level with the bottom. Gravity is your friend.
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 01:04 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
HELP QUICK Electric Fuel Pump Leaking 66 T-Bird Engine 4 06-06-2005 06:26 AM
Electric Fuel Pump Issue Eazy (Jax, FL) Electrical 1 06-29-2004 04:28 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
