Man, am I jealous. 56 Ford truck is my mostest favoritist style of truck, bar none.
As far as parts go, Grab a Summit Catalog. They show some Holley and Barry Grant pieces that sound like what you want. Might not hurt to call or email them to find out what they have at the best prices. Apparently everything they have is not necessarily listed in all their catalogs. Good Luck, Skidmark |
if you have a napa in the area a p5000 will work . i just bought on for my project and am running a 4.3. also your regulator is built in at the injectors and handles up to 100 psi
I am running a 35 with TPI in the hot rod and the fuel pump that I am using is an external unit for a ford pickup with a 460. I think it is for a 88 to 92. O'reilly keeps them in stock.
The Mallory 110FI should do the trick. Summit also sells a an inline pump made by Holley that should work.
Chris |
Fuel Pump
Hey 56rodder, I'm putting a 91 TPI in a 57 Chev. PU. I got a MSD elec. pump from either JEGS or Summit, don't remember which. Got everything hooked up, turned power on and promptly blew a hole in the factory fuel regulator. According to what I've been told by Mr. Goodwrench, the factory in tank pump puts out about what the factory regulator is supposed to bypass at. I had to replace the factory regulator and add an aftermarket regulator between the pump and factory regulator. There is a possibility the original factory regulator was tired and just decided to go at that particular time.... Didn't want to chance another blown regulator. Good Luck djenn
