Electric Fuel Pump Install??? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-28-2012, 01:08 AM
lg1969's Avatar
Google "Tunnel Ram 406"
[IMG][/IMG]
  #17 (permalink)
Old 12-28-2012, 11:24 AM
dmorris1200's Avatar
doesn't play well with others
So many possibilities…Is the pump running but not building pressure? Is the pump failing altogether? Is this only on highway, not around town (possible fuel starvation)? When it dies, do you hear fuel pump whine or is pump totally dead? If pump totally dies could be relay failure if relay is used in circuit. Excessive current draw could cause overheating of the pump. Verify all connections including all grounds. If the pump is running but not supplying fuel there are other possibilities. Pump should be installed as close to tank as possible otherwise you could develop vapor lock. If fuel tank is not venting properly could cause problem. I have seen bikes with stuck vent valves in gas cap more than once cause problems. After a few minutes of driving a vacuum would develop in gas tank and bike would fuel starve and stall. After sitting for a few minutes vacuum in tank would bleed off and bike would start only to do the same thing again. Figured it out when I noticed a hiss taking off the gas cap to see if I ran out of gas. Next time it stalled I popped off gas cap and she fired right up. New vented cap and no more issues. A cracked fuel hose between tank and pump could cause the pump to aerate. Also double check to make sure there are no issues in the tank, cracked pickup tube, etc. depending on how tank is set up. Main thing is to determine if pump is totally failing, if so check power and grounds. If pump is whining then check for vapor lock of pressure issue. As soon as it dies remove fuel hose from carb and crank engine to see if pump is pumping. A fuel gauge in the line to the carb is always a good idea for this exact reason. Always nice to verify fuel pressure at all times.
PS. Caspr49, always better to start a new thread of your own. You'll get more replies.
BUILT FORD TOUGH
  #18 (permalink)
Old 12-28-2012, 08:38 PM
DoubleVision's Avatar
Welcome Back DMorris. Long time no see.
  #19 (permalink)
Old 12-28-2012, 09:12 PM
hcompton's Avatar
Old & Furious
Not sure if anyone mentioned this but you can just buy a simple install kit. With relay and fuse.
Amazon.com: Mr. Gasket 40H Relay and Wiring Kit for 40 Amp Electric Fuel Pump: Automotive Amazon.com: Mr. Gasket 40H Relay and Wiring Kit for 40 Amp Electric Fuel Pump: Automotive
Hope this helps.
  #20 (permalink)
Old 12-29-2012, 08:01 AM
Wiki Edits: 27
crash switch needed
My son is a fireman and said he has been to a few crashes where the engine continued to run after impact. On his coupe he plans on using a crash switch to shut off the engine. Ford rangers, bronco II s have them on the side panel or firewall, easy to find, close to the passenger's feet, easy to reset..
