You will have to find the oil pressure switch/sender on your engine. Install a "T" fitting and re install the orig sender/switch on one end and the Holley switch on the other. Usually standard pipe thread, available at any hardware/home improvement store. Then run the pump circuit wire thru the switch to the pump.
There's also a spot at the oil filter that can be used for what your trying to do.
