Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electric Fuel Pump Installation
Old 05-17-2004, 04:04 PM
riesman20 riesman20 is offline
This is what I have so far. The ignition to the NO on the Press Switch then the NC to the Positive side of the battery then the C on the press switch to the relay but What point ? there is 30, 85, 86, 87. then from the relay to the battery(pos?), then from the relay to the fuel pump(pos?) than from the fuel pump to battery(neg?) is this correct?
ps. I have a fuse between the relay and the battery and between the ignition and the press switch.
