Could be an insufficient ground at the pump/tank etc. As the pump pressures up, the current demand rises,with a weak ground, the heavy draw can load the ground circuit and cause the resistance in the gauge circuit to change , causing a "floating " reading. Not sure if that is your problem here, just thinking out loud I guess.
Fact is stranger than Fiction |
I have had 2 different fuel pressure gauges on my hot rod that do the same thing. The only one that reads right is an NOS gauge I'm using as a back up. Try disconnecting the fuel line and see if you have fuel coming out. I bet it's just a gauge issue.
Keith |
| Recent General Rodding Tech posts with photos |
| Electric fuel pump, fan and water pump | Curtis Thornton | Electrical | 9 | 05-08-2011 01:41 PM |
| Electric fuel pump issues, flow | munster217 | General Rodding Tech | 2 | 05-04-2011 11:11 AM |
| fuel pump issues | southernculture | Engine | 15 | 07-12-2010 06:57 PM |
| Electric fuel pump to manual pump engine.. | RookieRodder | Hotrodding Basics | 7 | 02-14-2008 05:28 PM |
| Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? | zeeman19 | Engine | 7 | 02-13-2007 03:17 PM |
