If I were you and space permits I would go with the mechanical. I`ve tried many electric pumps, my last was a carter, all of them are so loud the constant hum drove me nuts, I didn`t even use it a hour before it was back off in favor of a mechanical. If you use a electric, make sure you set the mount with plenty of rubber on it to help isolate some of the noise. also make sure it`s mounted to where it gets plenty of air so it can run cool, 6 inches lower is acceptable, just make sure it`s close to the cell as possible. You may also want to look into a fuel pressure regulator, the carter pump I had was rated at 5 psi and it put out 9.
