Electric fuel pump return
Hey Guys.....have an electric (external) fuel pump feeding to my 350 with an Edelbrock carb. Should I have a return line and if so how do I install it?
What pressure does the pump produce?
Pat |
electric fuel pump return
Press. 5.5 to 9 lbs......what is a regulator??
Installed regulator today and still having backfiring thru carb no matter what press. is set at.
Set the pressure reg at 4.5 lbs.
Recheck the spark plug wiring sequence and where #1 is at. Does it start and run?
Backfires when I accelerate...most times when I start and sometimes when I shut it down.
| Holley fuel pump, return line or not to return line??? | JD's camaro | Engine | 1 | 07-16-2010 05:17 PM |
| Electric Fuel pump needs a return line ? | XRedRavenX | Engine | 4 | 08-20-2008 12:29 AM |
| Do I need a pressure reg and return line for this electric pump | camaro freak | Engine | 3 | 08-15-2007 08:50 PM |
| Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? | zeeman19 | Engine | 7 | 02-13-2007 03:17 PM |
| electric fuel pump return line? | meev182 | Engine | 4 | 05-04-2006 01:56 PM |
