electric fuel pump return line? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2006, 06:03 PM
I have a 1980 Transam that had a pontiac 350 with a mechanical fuel pump. I pulled that motor and im putting in a stroked sbc. In the process i decided id rather run an electric fuel pump. I bought a holley red pump off ebay with no instructions and i was wondering if i have to run a return line? I was under the impression no, but i want to make sure. This pump does not require a regulator. Any help is greatly appreciated.
Old 05-04-2006, 02:03 PM
73oldsman's Avatar
You might want to go to the Hooley site and look up info on the pump you have for pressures and specs and instructions.
http://www.holley.com/types/Electric...Carbureted.asp
Old 05-04-2006, 02:27 PM
SmallBlock_guy's Avatar
I have run a holley RED with no return line and had no issues. I now have a BLUE and no return. I have not had any issues and have been told that this can be done on a BLUE with no issues.
Again, I had no return on a RED for many years with no issues.
Old 05-04-2006, 02:36 PM
Wiki Edits: 31
if u want a return line, I'v seen people put T's in the fuel line and run the return back into the main feed line b4 the pump with a check valve so it don't go up the return, dosn't really return but does it's job by recirculating out of the main fuel system, with discharged preassure.
Old 05-04-2006, 02:56 PM
Thanks alot you guys, i appreciate the responses.
Can I run a small electric fuel pump w/6v system 40chevy Electrical 12 05-01-2006 12:16 PM
fuel regulator return line zephyrc Engine 14 09-16-2005 05:56 PM
electric fuel pump quinncamaro General Rodding Tech 7 01-29-2005 09:06 AM
electric fuel pump LL Ppainter Engine 13 11-16-2004 08:12 AM
electric fuel pump amerikian Engine 2 05-02-2003 08:20 AM
