electric fuel pump squiggy - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2012, 05:59 PM
New Member
Last journal entry: 1950 F-1 ford p/u
hi everyone fantastic site... does anyone no where to put the eleletric fuel pump on a 1950 f-1 ford truck i no it should go on the frame rails but i have the exust abot 3 inches away from the pump or could i mount it in the box where the tank is than run my lines down the the floor and go from there ok thank you take care ...
Old 04-21-2012, 06:12 PM
LATECH's Avatar
Hi Squiggy, cool handle btw.
Hee Hee.
The pump should be mounted back very near the tank, and down low , low as possible , as low but no lower than the level of the bottom of the tank.Keep it away from the exhaust.
Are you running a carb? or EFI?
Old 04-22-2012, 06:23 PM
New Member
fuel pump squiggy
thank you for the reply yes its a carb 350 motor i have duel muffers right there by me puttin it in the box the tank its self is about 12 inches hi i thought maybe i could mount it down at the floor on the inside ok ty take care RICK M...
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
45+ electric fuel pump cu42 General Rodding Tech 5 10-16-2009 10:48 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
electric fuel pump LL Ppainter Engine 13 11-16-2004 07:12 AM
