Electric fuel pump straight wire to Ignition - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2011, 09:33 PM
My FE Galaxie's Electric fuel pump is wired direct to the Ignition curcuit.
I runs for a while great then chokes out and dies I'm thinking it needs a relay
or maybey a switch . Any Ideas?
Tom
Old 07-24-2011, 10:17 PM
Overdriv's Avatar
Well, two things first off. I think any device that pulls more than 5-10 amps or is a long way from the battery or alternator should be controlled with a relay.
An electric fuel pump should be controlled with a relay and a safety switch of some sort, oil pressure, roll over, collision, etc.
With that said, I would doubt seriously that the fuel pump is causing your flooding problem. If it has a built in regulator, it might be going south, but sounds more like a carburetor problem to me.
Old 08-14-2011, 08:29 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
That car came with a mechanical fuel pump driven off the cam. It supplied the correct volume and pressure of gasoline to the carburetor. My best guess is that the electric pump supplies so much pressure that the fuel is being forced past the needle and seat in the carb and is blowing raw fuel into the intake manifold. The motor is able to tolerate this for a little while each time you start it, but it soon succumbs to the ultra-rich mixture in the intake manifold. The cure is to install a stock mechanical fuel pump.
Old 08-14-2011, 11:25 PM
ScojoDak's Avatar
Mopar for life!
Absolutely utilize a relay and wire it correctly. If it's pushing too much fuel, get a regulator. However, you may have to run a "return" style fuel system. Or as mentioned before, go back to the mechanical pump.
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Quick Fuel 30-125 125 GPH Electric Fuel Pump 64gto71cobra Engine 1 04-27-2011 11:25 AM
Fuel pump, electric choke and windsheild wipers on same wire sexypizzaman Engine 8 06-05-2008 07:23 PM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
